Yna
Hi guys!
I encountered an error on vijeo citect HMI. The system is configured as main and standby HMI.
I have this error on standby HMI, "ERROR 0x21 ON OPENING 'PORT1_BOARD2_SBY' FOR PROTOCOL 'MODNET' ". This error occurs if I run the the citect on first attempt. Upon closing the error dialog box and re-running the citect on the second time, the error is no longer available and I can run the citect....but if I exit again and run the citect, the error occurs again. I have to close it again and rerun the citect.. Same configuration both main & standby, but error occurs only on standby. How can I fixed it? Thank you in advance..
