Vijeo Citect HMI Error
Yna
Jul 2012
Metro Manila
37
Hi guys!
I encountered an error on vijeo citect HMI. The system is configured as main and standby HMI.
I have this error on standby HMI, "ERROR 0x21 ON OPENING 'PORT1_BOARD2_SBY' FOR PROTOCOL 'MODNET' ". This error occurs if I run the the citect on first attempt. Upon closing the error dialog box and re-running the citect on the second time, the error is no longer available and I can run the citect....but if I exit again and run the citect, the error occurs again. I have to close it again and rerun the citect.. Same configuration both main & standby, but error occurs only on standby. How can I fixed it? Thank you in advance..
It may not be relevant, but I have had the same error number when starting a project using MODBUS protocol and it was due to the serial port specified for MODBUS not being available.
Can you check that the port you are using is available and free before you start the project?
Iain
I’m using HMI/Vijeo Citect and I want it to take care of some calculation, not the PLC. How to do that, how do I let the Citect constantly make...
1,766
My system are taking data from RHT sensors, around 45 points. Now I want to make a function in which, if the data is #BAD or 0 in values for all...
479
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,671
I need help with vijeo citect 7.4 as I use Modbus TCPIP to get the data, it turns out the address is having error.. For example, when I write...
888
Hi everybody, I have a simple question for anyone who knows.We cant try because system is working and we dont have a permission about it. We have...
734
