Step 7 profinet redundant ring config not working seamlessly
HJTRBO
Jul 2008
Melbourne
618
Hi all,
I have a im151-8 cpu as the ring manager and three im151-3 pn as the ring clients. I have set up the hardware configuration and the ring topology without any consistency error. I have the units connected on my test bench with the profinet cables connected exactly as i have configured in the topology editor. I am not using any switches or hubs. All componenets are at the latest revision level.
However when i pull any ethernet cable out of its port it takes 1 to 2 seconds for the bus to recover which results in the loss of i/o data from the affected station. Additionally all outputs on that station are switched off.
I was under the assumption a redundant ring configuration at the i/o level would not suffer this and would seamlessly transition into the redundant state? Am i missing a simple configuration step?
Just finished up a heap of searching over a the siemens forum. Looks like i have to blow the watchdog timer out to 200+ms.
Hello, I have a Step7 5.5 project with a large number of profinet devices which will be activated/deactivated from time to time. I can use SFC12...
2,935
I am having a step7 v5.4 program where the blocks are encrypted and locked. And the manufacturer is stopped the support. Is there any ways to...
227
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
271
HI! HOW COULD I OBTAIN THE NAMES OF THE STEPS OF A ROUTINE IN SFC LANGUAGE IN STUDIO5000? Or is there a system variable that gives me those...
364
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
596
