GE FANUC 90-30 AND RX3i SCADA SYSTEM
engineerjaber
Sep 2013
Ramallah
23
HELLO GUYS,
I'M WORKING ON A PROJECT THAT AIMS TO JOIN 50 PUMP STATIONS TO A SCADA SYSTEM :)
THOSE STATIONS HAVE VARIANT TYPES OF PLCS :
GE : FANUC90-30 AND RX3i.
SIEMENS : S7-300 AND S7-200.
TWIDO40
MODICON M340
MITSUBISHI.
ZELIO.
DELTA.
I'M SO FAMILIAR WITH TWIDO 40, MODICON, DELTA, AND MITSUBISHI, BUT NOT SO FAMILIAR WITH THE OTHERS. :(
I'M GOING TO CONNECT THESE PLCs TO AN ACE3600 MOTOROLA RTU THAT SUPPORTS MODBUS PROTOCOL (RTU, AND TCP IP)
I HAVE THE PROGRAMMING SOFTWARE FOR EACH PLC.
TOMORROW, I WILL START WITH GE PLC :
1- HOW CAN I GO ONLINE WITH THE PLC?
2- I HAVE TO UPLOAD THE EXISTING OPERATING PLC PROGRAM. "BACK UP COPY" HOW CAN I DO THAT ??
3- CAN I DO THE PREVIOUS STEPS USING ETHERNET? HOW?
4- CAN I CONNECT THE PLC BY ETHERNET TO MODSCAN? HOW ?
4- WHAT DO YOU ADVICE ?
PLEASE, IT'S A CHALLENGE, I NEED YOUR HELP :)
THANKS
With the GEIP ones, the installation DVD has tutorials and manuals, that give you step by step instructions. If you get stuck on a step ask here about what you do not understand.
If you are in a big hurry, I suggest that you hire someone who knows to assist you.
I have a really old "Proficy Process System 2.0 SP1" (which is now called PME). My problem is that i have a CPU module IC695CPE305 in the Rx3i...
3,279
I am new to the GE Fanuc RX3I PLC. Does anyone have a section of ladder logic from their GE Fanuc Rx3i that they can share with me. Logic...
1,104
Good Day, I am Experimenting with Some more Modbus had had a few questions Regarding the Rx3i and Modbus. I have a big solar project At My home...
2,236
Hello, I Have a GE Fanuc RX3i that I migrated that Has a IC695CHS012 for the Main Rack and 4 IC693CHS392 Expansion Less than 50Ft. I ran across...
1,810
I know Once again I may be sailing in Uncharted Waters but thought I would throw it out there anyway. I have a Emotron TSA52-450 Soft Start with...
5,628
