GE Fanuc RX3i and 9030 Expansion
sjohnson
Feb 2010
MI
247
Hello, I Have a GE Fanuc RX3i that I migrated that Has a IC695CHS012 for the Main Rack and 4 IC693CHS392 Expansion Less than 50Ft. I ran across where they had a IC693APU300 Rev H High Speed Counter Module in the 2nd Rack IC693CHS392 and I could not get this to work in the Expansion and Had to do some changes and Put it in the Main Rack and it worked as it should. In GFK-2714 It says the Module will work in the Universal CHS or the 693 Expansion. Anyone ran into this or know if I may of done something wrong.. I did notice the OK was lit but the CFG was not in the Expansion but in the main Rack Both were lit..
1.3.2 Series 90-30 (IC693) Modules for RX3i Systems
The following table lists the 90-30 modules that are compatible with the RX3i serial bus in Universal
Backplanes, RX3i Serial Expansion Backplanes and 90-30 Expansion Backplanes. Page 8-9
I have a really old "Proficy Process System 2.0 SP1" (which is now called PME). My problem is that i have a CPU module IC695CPE305 in the Rx3i...
3,253
I am new to the GE Fanuc RX3I PLC. Does anyone have a section of ladder logic from their GE Fanuc Rx3i that they can share with me. Logic...
1,094
Good Day, I am Experimenting with Some more Modbus had had a few questions Regarding the Rx3i and Modbus. I have a big solar project At My home...
2,218
I know Once again I may be sailing in Uncharted Waters but thought I would throw it out there anyway. I have a Emotron TSA52-450 Soft Start with...
5,594
hello I have a project that contains a program with a RX3I controller (IC695CPE305), And I protect this project with a password but I have to...
3,544
