Unity Pro XL 5.0 and Windows 2008 R2
kutuz
Mar 2010
AB
29
Hi all!
I need to install Unity Pro XL 5.0 on Windows Server 2008 R2 for Remote Desktop Users (Thin Clients). I installed UnityXL 5.0, but none of my Remote Desktop Users can run the software. They get an error:
>Failed to find a valid license!
>Unexpected Error: One or more of the license components could not be loaded.
>Please reinstall Unity Pro XL.
The software is registered, I can run it under a local admin account.
Does anybody know if there is anything special how to install Unity Pro XL 5.0 on Windows Server 2008 R2 for RDP clients?
Thanks.
It might be the type of windows but first try to resolve this
Access rights on directories on the computer
Unity Pro needs to have read/write right access on the following directories:
C:\Program files\Schneider Electric and C:\Windows (when the disk by default is C:)
When Unity Pro user is not administrator of the PC, the administrator must allow the read/write right on these directories.
The above is noted in the readme. It might be your problem
Thanks for the answer.
I think the problem is in Remote Desktop Users for Windows Server 2008.
Even if I am logged in as Remote Desktop User but I want to run Unity under Admin - it gives me the same error.
I know that the UI for RSLinx Classic doesn't come up if you remote desktop to MS Windows Server 2003.
Hi all So i recently moved to a windows 10 laptop and installed Unity Pro 11 and all seems to be working correctly, except for the USB connection...
11,443
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
189
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
410
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
735
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,948
