ProSoft MVI69-MCM Block 3000
mike.m
Aug 2011
Liverpool
Im having a bit of trouble trying to figure this out any assistance is greatly appreciated...
Im using a Rockwell L32E compact logix controller with a Prosoft MVI69-MCM modbus module.
I have the plc set as a master polling up to 50 slaves. I have a poll interval of 1 second per command, a error retry of 3, error timeout 1 second.
The problem I have is when several slaves are powered down the comms slows right down 4 seconds per powered down slave (1 sec time out 3 retries)
I believe I can use a special function block 3000 to disable polling these devices.
Question is how do I use this 3000. I confused as to how to actually go about using it.
Thanks in advance
Mike
I have not used that specific modbus module, However, I have used the MV156. In the literature that prosoft provides, they indicate which specific bit enables the read/write commands. I don't have it in front of me at the moment, but from memory I think it is something like Port0.command or something like that. As I recall, there is a bit in that array that you could toggle to enable 1 or disable 0 a particular read or write command. The problem that I would see is that, as I recall, changes to that configuration require the module to be reset. You could always call Prosoft and describe what you're trying to accomplish. There tech support has always been very helpful to me. Good luck!
Thanks for your help Mark, I did have the manual in front of me yesterday I just could not for the life of me figure out how to do it.
Yesterday was a long day ill give it another go tonight with a more clear head, I cant see it being that complicated.
Thanks again.
Hi everyone, I’m trying to copy the configuration from one MVI69-MCM to another. I am having no luck establishing serial comms with the device...
145
Dear colleagues, could you help please. I have Prosoft Modbus module MVI69-MCM for CompactLogix PLC. With this module I need to communicate with...
657
Dear all, I am desperate for some help with a Prosoft DVI69-MCM MODBUS module. Details: Prosoft DVI69-MCM MODBUS module set up as slave with a...
5,747
Hi, I'm trying to integrate an MVI69-MCM module into my project. I need to be a Modbus slave and I need to send and receive data. I'm really...
6,267
Hello All, Quick question regarding polling a Modbus device (NuFlo Scanner 2000 flow meter) with a AB CompactLogix and a Prosoft MVI69-MCM card...
6,759
