Omron C200h
francevendee
May 2005
Wales
48
I need to upload a program from an Omron C200H.
What do I need?
I have a copy of SYSWIN34, Omron CPM1-C1F01 Interface unit and serial lead.
Is this all I need?
If so How do I do it?
Never jumped on an Omron before.
Do NOT use the CPM1-CIF01 with the C200H. It won't work and you may damage the cpu. This would work with C200HS and C200H alpha units but not a C200H.
You will need a Host Link Unit. If you have an open slot in the rack, use a C200H-LK201. If not you can use a cpu mount unit, 3G2A6-LK201.
Syswin will work with the C200H, as will CX-Programmer.
I have a sysmac omron plc C200H CPU01,only the power led is ON,using CX-ONE programmer software, and connecting to the plc via Host link LK202-V1...
743
In order to upgrade a control unit, we need to backup program of an omron C200H CPU01 with host link LK202-V1 that has RS422 D9 Connector. Please...
635
The logic seemed to convert nicely, and I had to make changes to the addresses for my AD and DA and 32-point input cards. The current problem is...
1,049
I am trying to display some scaled analog input values on a C-more Micro terminal, from an older C200H Omron PLC. The addresses appear to simply...
2,201
I have a customer with the Omron C200H that occasionally will start flashing the alarm light and the machine stops. They say they can power down...
3,114
