GE Versamax Moving data between processors
tmechanic
Aug 2005
New Richmond, WI
40
I'm having a little trouble getting some bits and a couple Int variables to move between my 2 Versamax PLCs, I need to get several control bits and a couple variables so they can be used in different processes.
I'm drawing a complete blank on how you do these moves in Proficy.
Can I make multiple targets under the same project, one for each PLC, to make these data moves easier? Would the 2 targets share the same registers for %T and %R?
If your CPUs support EGD, it is the easiest to set up, and fastest of the ethernet protocols.
Hi Everyone, I own a GE Versamax controller that I purchased for a class at Long Beach City College a couple of years ago. I lost the use of my...
209
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
250
Hi, The VersaMax PLC suddenly stop running (no LED on run function) so I'm trying to upload the program. The HMI connected to it says "Host...
151
I do have a problem with a GE Versamax micro PLC. By going online (on Port 1) the "OK led" goes down. Power led stays On Port 2 no reaction at...
413
Hi, I am trying to set the IP address on the IC200UEM001 Ethernet Option Module. I am following the procedure in the manual for setting a...
450
