how to wire a relay module 5v from plc to a soil moisture sensor?
Jul 2016
Philippines
hello, i have a problem in wiring my relay module board 5v from plc to my soil moisture sensor, i already have a 5v power supply, i just dont know how to wire it at the relay module, heres the specs for the relay module, and im using a 2 channel relay because im using 2 moisture sensor, please help thanks
relay module specs
http://www.geeetech.com/wiki/index.php/2-Channel_Relay_module
here is the specs for the soil moisture sensor
https://www.dfrobot.com/index.php?route=product/product&product_id=599
What PLC?
What output module?
Relay or Triac output module?
Part numbers first before we can give any help
Ok, just had a look at the link. I ASSUMED (bad) it was a PLC, but I see it is a Ardinio. Sorry, can't help you there
Most PLC is 24 Volt, so if there are relais contacts use these to switch 5 Volts.
Better is to use an arduino though.
The moisture sensor will also need a special analog input on the PLC, however the arduino can be connected directly.
What is your set up
Those sensor will almost certainly have to go to an arduino and have the arduino act as a tranmstter to send a plc friendly signal is 4-20mA or 1-5 v
Or is this project purely arduino
If it is purely arduino all the info, wiring diagrams and code samples, or in the link you provide
If you are trying to wire those units to a plc is there a reason why
They were never really meant for that purpose
I hope this is for training purposes.
IMHO...
Any business who allows Arduino be used in an industrial environment for production equipment will likely regret the decision but will deserve what they get.
Does anyone have experience wiring this type of analog pressure transmitter up? It's 4 wires. 3 blacks and 1 green which I assume is earth...
264
Hi everyone, I need some help I new with omron plc. I using plc CP1L. When I do the program it's good and the plc is function as program. But when...
86
Hi there, Trying to get some ascii serial communications working via RS485 (COMMREQ functions). I have attached our wiring for the COM2...
969
What's everyone use for I/O drawings on new installs. I am trying AutoCad Electrical, but can't download it due to a MS Office application running...
1,309
I've been tasked with adding a 3-wire pressure differential transmitter to a system and drawing up the wiring to an existing PLC board. The...
781
