Automation Direct Timer in ProSuite 2000
croakus
May 2004
Dayton, OH
101
Hi.
I've been looking for an AD version of AB's timer timing (TT). I can't seem to get it to work using the AD TMR instruction. Trying to use the <Preset activates right away when I download - even when the rung conditions in front of the TMR aren't true.
I'm trying to turn on an annuciator (triggered by a one-shot) for three seconds before rotating a table. Normally I would use the TT to latch around the one-shot and turn on the annunciator, then use the DN bit to initiate to table index.
Thanks for pointing me in the right direction,
Croakus
There isn't a standard Timer Timing (TT) bit in the Productivity Suite. You will will have to build one. See the attached picture.
Then you can use the created TT bit in the program.
I thinking of trying one of these PLC's for a project but have noticed that you have to pay for the manuals. It makes me wonder about their tech...
9,903
Hello, I have an automation direct d2 262 plc and C-more HMI EA9T6CL-R. I need to prepare a program, scheduled to be performed on a future date. I...
119
Hello all- I have a unique challenge using a customers Direct logic 06 PLC. This customer has a DC motor operating at 10 RPM which is turning a...
136
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
565
Anyone tried Automation Directs new CM5 HMI. We've been the EA9's for a few years now with minimal complaints. A few failures here and there but...
17
1,588
