Panel View 1200 Configuration Software
mptilly
Mar 2004
Covington, LA
I've got several Panel View 1200's that came from a PLC-5/40 and PLC-5/60 environment (but don't have the PLC-5). I need to test the Panel View 1200's to ensure that they are working properly (verify communications links). Any idea where I can get a copy of the Panel View 1200 configuration software? I believe that with the software I can modify the configuration to work with a different model PLC. Any other ideas on how to check the full functionality of the Panel View 1200?.
problem in communication between micrologix 1200 & Panel View 600 Plus by serial DF1 Hello Friends i have to do communication between micrologix...
6,611
hello everybody, I am new. Is there any one having eperience on communicate between panelview plus 600 and micrologix 1200 plc controller? 1...
51
39,917
Hi I am trying to communicate panel view plus compact(cat no. 2711PC-T6C20D) to MicroLogix 1200 through Serial RS232(DF1 protocol). But i cannot...
6,080
Hi I'm new to the forum and need your help because I have a PLC 5/25 with a Panel View 1200 Terminal by RIO communication which is causing me many...
4,478
Hi everyone; I have an pv 550 touch, and I want to see him on rslings, I have a usb to serial converter and 1747-uic, my pv has 2 ports DF1...
4,616
