Trigger FT View SE Graphic Display
mm08822
Apr 2016
NJ
Hello all,
I would like to trigger a graphic display in FT View SE 8.1 from a ControlLogix PLC by setting a bit. I can't find how to do this in FT. Any suggestions? Thx
Welcome to the forum!
In ME (machine edition) - easy.
In SE (site edition) - royal PITA. You'll have to use VBA.
Check out this thread which is me trying to work out the exact same thing. I eventually got it working with the information on that thread.
Thanks, ASF. I will use that vba code as a guide and put it into my navigation button display that is always open.
I am trying to have my Alarm Summary page open when an alarm goes active (I am using ALMD blocks) this is the expression I am trying to use...
1,227
Hi all, i need some help with this little issue. I wanna open a popup in any display when an alarm is triggered. I think this can be do it using...
2,014
I have a FTView ME project and i want to be able to logout the current user based on a PLC Trigger (keyswitch). How can i implement this? Is...
2,893
Since you can't have a trigger value=0 in the alarm setup, you need to start with 1 but in my logic/FTV my xxxxx[0].0 = trigger value 1. How...
7,589
Hi, I wonder If there is a way to trigger an action i.e. open a pop-up when an alarm occurs (not applicable for all alarms only for selected...
2,990
