Since you can't have a trigger value=0 in the alarm setup, you need to start with 1 but in my logic/FTV my xxxxx[0].0 = trigger value 1.
How would I be able to work around it so that the bit level in the logic = trigger level in FactoryTalk View. ( ex. Safety_Faults.Faults[0].1 is Trigger Value=1 in FTV, not Trigger Value=2
Am I not doing this the correct way? I have tested the HMI application with an emulator with copied logic from the original work so that I know the correct alarms are matched whats going High in the logic.
FTV V8.0.0
RsLogix V20
Thank you!
FTV V8.0.0
RsLogix V20
Thank you!
