FactoryTalk View ME Alarm Filters
Viks
Jun 2008
Hamilton
157
Hi guys,
I'm trying to figure out a way to filter out area alarms on my panelview. My alarm labels have the area code as a prefix of "A2" eg. A2PE1101, A2CY1101. I've got multiple areas which are part of the alarm label. I know I can use the filter option in the alarm list object and select all the labels which have the area suffix to filter them out per area. What I need to know is if there is a wildcard option available on the filter so instead of having to select them using the check boxes, could I just use a wildcard like A2* in the filter and that filters out all the labels starting with the prefix A2. I've tried using this wildcard but nothing comes through. Dont even get any errors that the alarm list object is unable to resolve the filter. Having to select check boxes may be suitable for projects which dont have many alarms but for projects which have 1000's of alarm labels to filter, its a bit of a pain.o_O
I'm pretty sure I'm not the first one who has come across this situation so if anyone has done this successfully in the past, would you be kind enough to share your ideas. Thanks
ME version 10 (CPR 9 SR10)
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
133
Hi all. I´ve got a little problem with my FT View SE alarm window. On my PLC program, I have 200 SINT for alarms, in which every bit is for one...
182
Hello everyone, I am experiencing a strange issue with machine using a PanelView Plus 7 and a CompactLogix 1769 PLC. I am using FTView ME V13...
334
Hi All, I'm currently designing a faceplate for an analog input object, and I'm trying to create an alarm tab with an Alarm and Event Summary...
443
Hello! In FTView SE 13.00 for the AlarmEventSummary1 object I need to add the filter Alarm Name LIKE % %. In the field % % I want to pass a...
546
