Red Lion HMI to SLC5/05, values stop writing to PLC
AutomationTechBrian
Jul 2013
St. Cloud, MN
671
I'm gradually replacing a Windows 2000 PC running Wonderware with a 15" Red Lion HMI. The application is a large plastic extruder. Right now, the PC screen and the RL touch-screen are mounted on the same panel, next to each other. Some machine functions have been moved over to the RL, and I'm working on moving all of the temperature and pressure displays to the RL.
Yesterday, I was adding temperatures. The Eurotherm controller sends PV values to the HMI, then I added a block to write those values to the N30: locations in the SLC. I was monitoring the N values in RSLogix500. They worked perfectly for about 2 minutes and then they stopped. I haven't been able to get them to write to the SLC since then. All affected addresses are zeros. It appears to only be those values, but I'll double-check that today.
Any thoughts on what happened?
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
91
I am having issues getting a Red Lion HMI and Micro830 controller to communicate. I am using the cable here to connect the controller to the RS232...
135
Hi I need to send a null command down a comms port. But in the crimson software when i used /x00 it coming back "Cannot use null character is...
435
Hi Everyone, I am hoping a Red Lion Expert can point me in the right direction. I am experimenting with data logging on a CR3000 10" screen...
632
I have a Red Lion G09 scanning 8 Invertek P2 VFDs via modbus RTU - I've setup necessary comms and tags and all works well. I have a 'Settings'...
1,895
