How to create footer for navigation in factory talk studio me
There is nothing specifically designed for doing that but what you need to look into is global objects. Create the navigation template as a global object then you can cut and paste it to all the screens and it remains linked to the original. You can edit the global version and all the screens will update.
Put all the bits in a group so you can add things to it later.
The way I have seen it done (many years ago), is with multiple displays on the screen, one being set up with its position at the bottom serving as a navigation pane and the main part of the screen being set up with the required bottom number of pixels chopped off.
The only advantage being that you did not have to paste a global object on every page.
IIRC, it was necessary to ensure that the menu was set up as the Startup Display and there could be issues if you didn't get the positioning right or if you needed to have certain buttons hidden at certain times, so for those reasons I think I would like Geoff's suggestion a little bit better.
Hello, I've been trying to learn this a while now and still have not found out how this works. I have an Omron CJ2M PLC and an ABB ACS 355 VFD...
243
Hello, I have to deal with iFix again and am looking at the most efficient way to create alarms to display in iFix, i.e. not creating an...
155
Good morning to all, I have the following issue, I installed everything of intouch including the patch, it is the 2023 version. The...
330
So, I finally got versioin 27 installed on my Windows 10 VM. However, now I can't upload a project from my lab controller. I have the above error...
1,129
Hi all, I have few GB of logged data created by RS View 32 Works, it is all in .DBF format. At the moment, my company wants to shift all data to...
1,452
