DCom Member D Join Date May 2016 Location Conroe Posts 20 Nov 8, 2018 #1 Did Rockwell discontinue their NET ENI Configuration Utility Software? I searched their site and many other sites on different search engines but to no avail. I am in need of the software to program one. Thanks In Advance
Bob O Member B Join Date May 2003 Location Posts 1,875 Nov 8, 2018 #2 You may have to login... https://compatibility.rockwellautom...rumb=112&refSoft=1&toggleState=&versions=3951
shawn_75 Member S Join Date Apr 2010 Location KY Posts 432 Nov 8, 2018 #3 You can do most of what you need to program via telnet. telnet 192.168.1.1 1500 (substitute your IP address) For other parameters you can message the nodes using a message instruction from your PLC.
DCom Member OP D Join Date May 2016 Location Conroe Posts 20 Nov 8, 2018 #4 Thanks. The link worked perfectly.
