Problem with connecting Unity Pro S and Vijeo Designer
timcph2008
Jul 2015
United State
33
Hello,
I am using Unity Pro S V8.0 and Vijeo Designer V6.2, both are not licensed yet.
I followed tutorial video from youtube but I still cant get the same result with the videos.
Here are the things I did on Unity and vijeo:
Unity:
- Configured an Ethernet network, IP 10.10.10.1, Mask 255.255.0.0
- Built a basic motor control logic.
- Export projects as STU file.
- Build and Run PLC, no error and warnings
Vijeo:
- Configure a new equipment in IO Manager, IP 127.0.0.1 and TCP as protocol, also checked IEC61131 Syntax.
- Configure the Network, IP 10.10.10.1, Mask 255.255.0.0
- Linked the Unity variables.
- Created a lamp on HMI, set the variable as the Motor from Unity.
- Build and Start device simulation, no error and 1 warnings
"warning 2131: Enable Downlad Security to reduce unauthorized access to the target machine"
- HMI open successfully, but no action after I force value on Unity.
Do you guys see any mistake from the above information? Please leave any comment, and thank you for your help! :geek:
you panel needs ip address from same ip range than plc if you use ethernet cable, otherwise they will not communicate.
So give to panel ip like 10.10.10.2 or other from 10.10.10.x IP range. If you use RS485 or usb then panel don't need ip address.
And welcome to the forum.
Hi everyone ! I have a problem. I've hope You could help me witt that. I want to connect my plc SE m340 p3420302 module with my PC via ethernet...
8,995
First of all Hi, nice to met you all. I have a problems trying to control my PLC's (1762-L40BWA ser. C and 1763-L16DWD ser. B) with the Panelview...
5,053
Hello! We have one Omron NT11-SF121B-EV1 display and CP1L PLC. I want to connect this display to computer and upload graphics with NT-series...
2,339
Greetings i do have a new Siemens PLC station with 314 CPU 1DP i try to connect using the PC adaptor Cable USB A2 i do have the Error message...
2,239
Hi all Was wondering if you guys were able to help. I am onsite trying to program a 440C-CR30-22BBB Safety relay. Using the following pdf and...
4,379
