Monitor and Record
TRACY H
Jul 2004
72
We are looking at a Honeywell HC900 hybrid controller with a
Model 1042 to monitor and record the temperature of bearings.
Does anyone have experience with these or a better idea for
this application.
Why not use RTDs into PLC RTD cards and then use a simple SCADA system over the top?
It would be a lot more flexible and you would then have the opportunity to send SMS alarms etc.
yes good way to have bearings in control.
we do it manually now as there is always a watch on the ships. and yes there is an alarm working on it. and the readout is logged in to the big machinelogbook.
so i would opt for a tempalarm/readout on each channel.
however if you have experience with these hybrid recorders they can be used for this purpose.
put the scantime fast but the print time slow.
use alarm switch of recorder to give alarm.
yesterday i used two yokogawa recorders with each 30 channels to have usda certificate to transport fruits to usa.
DATA
BobB
Thanks we`ve looked into plc`s but we need about 60
thermocouple signals and the plc and cards are quite
a bit more exspensive. Than the Honeywell stuff.
Shooter
This is what we have in mind. Just not familar with
Honeywell event programming. We were hoping someone
had hands on experience. đź“š
We have a quad monitor setup with FT SE and we are utilizing a header screen at the top of every display. when we open a new page we abort the...
93
Our plant manger/my boss wants each line to display the takt time above the line. I am trying to research the cheapest way to do this. Our plant...
187
Hi Folks, Looking for support and ideas. We are trying to go online to monitor/fault find on an S7-300 programmed with TIA Portal V15. I can...
352
We finally replaced our Cognex Checker with an IV-3 and I'm wondering if can replace the s/w in the monitor with anything else. I haven't been...
100
Im very new to programmin,but i was wanting to try and set up a program that could monitor the speed of a roller. Would it be possible to use the...
157
