FactoryTalk View SE Network 6.1 Datalogging
dsking
Dec 2008
ontario
66
HI All,
I recently converted my RSView 32 application to FTalk View SE local. The issue that I've run into is that my trending screens data is not saved. Attempting to view previous data yields nothing.
I've created data models and am not sure where the mistake could be. The application is not tied to any SQL server and am using RSlinx enterprise.
Please help.
What is "original SE format"? do you mean RS linx/ OPC server?
In View 32 I did not have any SQL sever configured and set up.
No. You need to log your trend data to a SE datalogger. Then the trend will get its data from there. There are two datalog formats: one uses the SE format datalog. The other stores its data in SQL Server Database. Then you configure the trends to get its data from the stored datalogger data.
Alarm Server Connection Status I am trying to tie a color animation to a rectangle that changes color when connected or disconnected from the...
526
We are cutting over a PLC5 to ControlLogix and we ran into some issues with the HMI (FTView v10, Network Distributed). We found that after...
961
So I am trying to animate a button that navigates to the alarm summary screen to blink red if any alarms are in alarm and unacknowledged. So in...
882
Hi Folks, I am having a bit of trouble with a Factorytalk View Studio Network distributed application (Surprise surprise) after restoring a...
1,097
Hi everyone. I'm working with a network distributed application, just a HMI server and a HMI client. I installed the SE Server package on a...
2,143
