How do I change a Panelview 550 RIO settings?
you press both the "left arrow" key and the "right arrow" key at the same time ... that should get you to a configuration menu ... then go to the "communication" selection and follow your heart from there ...
you can find all the details here:
PanelView User Manual
I'd start on page 3-2 [Adobe Reader page 66 of 278] ...
PS edit ... I see that Marc has a different take on your question ... software configuration ... I guessed that you wanted to access the hardware method ...
Changing RIO settings
Once the RIO settings are set and a program is downloaded to the Panelview, you can no longer change the RIO settings thru the configuratino screen in the Panelview.
When I try to change them thru communication setup, the program won't download....
I'm not sure I completely understand the steps you're taking ... but see if changing this setting helps ...
[attachment]
disclaimer: it's been awhile since I've messed with one of these ... but I have a spare one at home in my garage ... if all else fails, detail the settings you need and the exact steps you're taking ... if necessary I'll run a few experiments tonight and try to get back to you tomorrow ...
I think that PVs with RIO also have a serial port.
Depending on this setting it is set for either download or printing purpose:
[attachment]
If it was set for printing on a previously downloaded application, then you can no longer use it for download.
Is there a way to clear the program, so that the port will be available for download again ?
I do have the "use downloaded settings" turned on, and I am able to download a program to the Panelview...unless I change the rack number or starting module group in the comms setup, then it won't download.
I'm not in front of it right now and I can't seem to remember what happens...but the program does not transfer.
try pushing the "Help" button on the screen I posted ... this pops up on my version:
Specify whether to download configuration settings defined in the application. The default is to use downloaded configuration settings. To use the current settings in the terminal after a download, clear the check box.
Configuration settings include all settings defined in the Application Settings dialog.
Jesper,
This will also let get to the screen where you can turn the printer port off, then you can use the port for programming again.
Can anybody give me a procedure on how to change or edit the date/time of the AB PanelView 550? Thanks
4,662
Hey all, i have a panelview screen (image attached), with 4 items on it. Program 1, Program 2, ...3, ...4. The PLC i am using is a compactlogix...
258
Hello brothers We are contacting you because an error like [display change is currently controlled remotely] occurred while using the equipment we...
237
PanelView +7 Series B ME station disables network adapter on panel when I downgrade to Rev. 9 or 10. Used to work before with the Series B panels...
511
Hello, I was wondering if anyone could let me know how to change the audit trail messages language on Factory Talk ME. I am currently working...
472
