CPU 315-2PN/DP LED blinking with specific GSD file
santosh8665
Dec 2008
pune,India
hi,
i am installing GSD file with API field value as 0 & downloading project & it is working fine but , when i try to install same GSD file with API field value as 14848(hex value as 3A00 which is project specific)& upload the specific module to PLC, suddenly all PLC LED's are blinking.to stop PLC blinking i had to format the MMC card every time.i am not getting exact reason behind this specific GSD file behaviour.providing here both GSD files. plz help me to find cause behind this fault.
Thank you..
Santosh
Iam fining the Technical information of CPU S7-315 2PN/DP following: (1) Average fault time: (2) Annual system utility: (3) Acknowledge...
2,023
Dear Sir, I have faced a problem in SIEMENS PLC CPU 315-2PN/DP,the PLC is not communicating with the SCADA.I have called a service engineer,he...
1,893
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
204
I'll preface this by saying this is the first time I've worked on a Siemens system and I'm fairly unfamiliar with them. I might mess up some of...
29
825
