Omron NS8 HMI connect to barcode reader
IMSTUCK
Oct 2006
West Lothian
Hi, Has anyone connected a barcode reader directly into port B of this HMI (OMRON NS8). I have set this up in the comm settings for port B as it is an option but have no idea which memory location it is stored in. Cant find any help in NS designer help
I was able to connect a Microscan MS-3 Laser to an Omron NSJ8 HMI on port B. The trick is to create an String Input Display functional object in the active screen. In the string display properties select the Keyboard tab and change the input method to "Other Input Method (command button etc..)". In the properties window you can also select the General tab and set the memory location where the input string from the barcode will be stored in the "Address Information" field. You will also likely have to create two command buttons on the same screen one to enter the captured string and one to clear the String Display input. I say likely because it is also possible to do this with a macro, but, is more involved.
For Additional Info Refer To Manual V083 (Sec 3-4-4 & Sec 6-6-6)
I have an Omron CQM1H-CPU21 and a NS8-TV00B-V1, I have followed the manufacturer's spec on how to set this up and all I got is the HMI is trying...
895
Hi all, I have a customer that has a series of around 15 Omron CJ1M PLC's, each connected to an Omron NS8 HMI via an ETN21 module. The PLC and...
2,924
Good afternoon, I need to create a recipes display on the hmi ns8, to change the parameters of a servo and some strings . The PLC that im using is...
2,776
I have an Omron NS8-TV01B-V2 that will not start up. Has an error warning. I tried to create a program in CS-Design and down load to a flash card...
3,721
Hello friends, Can I seek your expert advise, I am new to Omron HMI/PT interfacing to Omron PLC. My question is how to communicate this to? 1...
3,680
