Zebra Printer Options
DesertDog
May 2003
North of Los Angeles
350
I have been tasked with printing machine output totals to a Zebra kiosk printer from a Siemens TIA Portal application using a 315CPY & TP1500 Touch Screen. . My initial hope was to print from the HMI to a KR203 using a Print Report form to a USB connection. This seems impossible with the KR203. I am now considering exchanging it for a KR403 giving me TCP access. It also has loadable font capability that the KR203 doesn't. I'm thinking that if it won't print through the HMI I should be able to get what I want by printing directly from the PLC. All I'm really looking for is a yes this will work before I make the exchange or a you should just return it. A push down the road if it's possible would also be appreciated, I have no experience with printing from the PLC or ZPL so it will be a learning curve.
*Attached is an example of what I need to print on a gas receipt type printer.
Well, the easiest way to print to this would be using Rs232 and pushing the ZPL over as ASCII.
Note, I've never used the KR series printers, so I would double check w/ Zebra that they'll still work like that, but it should allow you to build the ZPL code either manually or using some design software and just let the PLC put the variables in at runtime.
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
375
Hi All, I currently have an issue to establish connection between my PLC to Zebra Printer. On my side don't have the ASCII card Module to use...
766
Hi All Trying to get the PLC to send a commant to the printer to prinnt a lable. evarything is setup except RS linnx cannot see the printers and...
383
Hi All I'm trying to connect two zebra printers to th PLC through Ethernet. I can ping the Printer through my laptop connected to the private...
361
Hi there, i have 2 questions, first of all... I need help with the configuration of a Zebra Printer. zt410 I have created the module and still...
1,569
