OT - Searching for strong duct hose to collect hot metal chips
alive15
Oct 2015
Montgomery, AL
721
Good afternoon all, hope everyone is doing well. I have a mill cutter application which mills into our iron casting part. I am using duct hose 5314k36 from McMaster to collect the hot chips and shavings after every mill, but this one only lasts about 5 weeks before holes start appearing in the hose.
Does anyone recommend a stronger duct hose of any material from any company? Looking for a 10' piece or longer that can slightly flex on the ends, similar to picture attached. Our chip hose goes up vertically into a metal pipe which sends to the chip collector bin.
Thanks,
I don't have any experience with this product, but have you looked at 5261K71 from mcmaster? It looks like a similar hose, except steel and even more abrasive resistant.
@GaryS I checked on Grainger in the metal hose category, but they have only for gases, not for metal chips. Do you think those would work for metal chips?
@Helliana Thanks! I will definitely order a piece and compare the life with the existing one.
is it just me, or has something happened with the google search when using chrome? looks likes safari on mac is ok, but edge/chrome on windoze has...
834
Besides using BootP in the past, I am relatively new to having to look for privately addressed devices in many control networks. All of the...
23
3,940
Good morning, could anyone recommend a 24VDC pulse counter which counts up or down to a preset #? Once it reaches this number, send a 24VDC back...
1,647
Hi, Using FactoryTalk View SE version 9.0. Wondering if someone can help me as to whether or not I can search an entire display for instances of a...
2,297
Is there any way to stop a search from finding a text string inside a sub-tag name. For example: if I'm searching for "run" ... I only want to...
2,116
