1761-net-aic
aedaowz
Oct 2012
baja california
Hi Folks:
I'm trying to make connection with a 1761-net-aic module , 2 PLC, 1 PC..
I've connected a plc 1747-L532 (SLC500, 5/03) to port rs-485, I'm
using cable 1761-CBL-AS03 between plc and net-aic converter, also
I've connected a plc ML1000 to port rs 232(8 pin MINI DIN),using
cable 1761-CBL-AM00, between net-aic converter and PLc.
And from 1761-NET-AIC to PC. I'm using cable 1747-CP3, port (DB9,DTE).
I've configured in RSlinx driver 1747-PIC/AIC+driver:
For: ML1000 is AB_PIC.
For: SLC 500 5/03 is AB_PIC.
I can see only one PLC (SLC 500 5/03.)
What's wrong ?
Please help me Guys.
Baud rates the same on all devices?
Different node address?
A ML1000 series D or greater will sense the protocol automatically, what series do you have. If not "D" then is the port configured for DH485?
Thanks for your fast reply Mickey:
My PLC ML1000 is a 1761-L16BWA, serie E, FRN1.0
The settings of ML1000 -Primary Protocol DH485.
-19200 BAUD.
-NODE ADDRESS 1
-FULL DUPLEX
The settings of SLC500 -CH1 SYST. DH485. 5/03 CPU.
-19200 BAUD.
-NODE ADDRESS 1
CH0 DF1 FULL DUPLEX
-19200 BAUD
- 9 DECIMAL
ANTONIO E DAOWZ.
Hello, currently I have a micrologix 1200 (1762-L40AWAR )connected to an HMI panelview 600(2711-T6C3L1X) via the 1761-net-aic module, I want to...
1,807
I've attached pics, below. I'm in the field right now an am trying to communicate to the Micrologix 1500 through the 1761-NET-AIC (Ugh!) to...
1,956
The manual for the 1761-NET-AIC shows connecting a PC to DH485 network with a 1761-PM-02 cable. Is this done using a DF1 driver set to...
1,073
A customer of mine has a ML 1500 LRP connected to a Net-AIC+ via the mini din connector (CH 0 of plc to port 2 of AIC) from this AIC then connects...
1,794
I have a bunch of ML1000 PLCs on a DH485 network using 1761-NET-AIC modules and we are replacing the ML1000s with ML1400s. Once all of the...
2,011
