If the display is cached, then you will also need to flush the cache and then reopen the display to see any changes that you made graphically. Also, many systems are set up to put the most recently displayed page "on top" so that the one you changed might still be open behind it. So you have to close the display, flush the cache if required, then reopen the display to see your changes.
