PanelView 300 2711-K3A10L1 Programming cable
kennadrin
Feb 2014
Florida
37
Hey Guys
I am trying to figure out the correct cable to use to connect from my laptop to this Panelview using panelbuilder32. I was sure I had used my serial cable direct with a null modem on my Panelview 550 in the past. I can't seem to connect. I would appreciate any help you can give me.
Kenny
Thanks for responding
I believe I tried straight through. Didn’t know if maybe I was using the wrong setting In Panelbuilder.
Upon checking it does look like it should be a serial cable for PC to Panelview connection.
Before even trying anything with Panelbuilder, I would verify that you can see it in RSLinx.
I meant the correct settings in RSlinx sorry. I will have to check again monday at work. I think I tried both the df1 and aic setting. I didn't know if maybe the devicenet connector meant I had to try something different.
Kenny
Used a serial cable (with genderbender) this am. Using the df1232 setting in RSlinx worked perfectly.
Thanks for the help. Sometimes I need to slow down
Kenny
I am having pvc300 with me. I created my new program in ccw. The issue is that after clicking discover in ccw my hmi is not showing up there. Any...
146
merry christmas and happy new year i have a click c0-00dr-d and allen bradley 2711c-t3m. can the panelview talk to the click plc via modbus...
222
Is this the clock battery flat? Does anyone know how to remove the back of the PV 300 micro. Is it possible to replace this battery. AB says it's...
1,159
I need to utilize the program of Panelview 300 standard into Panelview 7 plus. Can anyone plzz help in this regard??
1,403
I have an opportunity to get some more experience replacing an old Panelview 300 Micro. I'd like to hear any advice you have about it. I suspect...
3,298
