I suffer from CRS
rsdoran
Apr 2002
Birmingham, AL
7,371
ionics said:
ML1200COMMUNICATION
thank rsdoran
i found your information is very useful
as ml 1200 communication port (com0)is not blinking means not configured as DH485,may be an other configuration may be rs232 .
there is allen bradley usb to serial adapter
(9300-USBS ),.
I WOULD LIKE TO ASK IF IHAVE THIS ADAPTER CAN I USE IT WITHOUT INTERFACE CONVEROR OR NO ?
I YES WHAT IS THE CONFIFURATION AND PROTOCOL .
THANK YOU VERY MUCH
Someone please offer more assistance.
Ron, I suffer from CRS-II. What I can't remember, I make up as I go along...
In the first attached PDF file, it appears that the 9300-USBS Adapter only converts from a computer USB port to a Serial (RS232) port, and it does not also convert from RS232 to RS485, so you will need another adapter to do that. The traditional one for Allen-Bradley SLC's was the 1747-PIC (Personal Computer Interface Card), but nowdays you need the 1747-UIC.
Can more then one macro be executed when starting a display or shuting down a display? If yes what is the proper syntax.
1,580
Hi ppl, i am new to this forum and want to get some help to connect Nais FP0 type plc to citect, it has only one (3 wire) rs232 port on the...
2,869
Greetings, Does some one knows how to use the PWM file in the Micrologix 1500, and if so, can that someone direct me to a sample. I am trying to...
2,931
