Controllogix 1756 & 1492-IFM40F-F120-2: Force a bit
leonlai
Jun 2011
WA
96
folks,
I have a controllogix 1756, DO Card (OW16) connect to 1492-IFM40F-F120-2. I did a test at a pin on 1492-IFM40F-F120-2, Force a bit on, and measure the voltage out on the pin, there is only around 4-6 Volts different, is it suppose when I force a bit, it should go from 0 to 120V ?
There are multiple unused pin on F120, I did 3 different unused pins and get the same result when I force those DO output and expect to see 0 to 120V, but only around 116V to 120V.
folks,
I have a controllogix 1756, DI Card connect to 1492-IFM40F-F120-2. I did a test at a pin on 1492-IFM40F-F120-2, Force a bit on, and measure the voltage out on the pin, there is only around 4-6 Volts different, is it suppose when I force a bit, it should go from 0 to 120V ?
A couple things. You say DI card. This would be a digital input, so you aren't going to read any output voltage on it. Did you mean DO? If so, what type of DO? OA16? OW16?
Yes, other pins with relay hook-up already are working fine. These pins which I test dont have relay hook-up yet. I just wanna do test before put 120V relay in.
I'm sorry as I am having trouble understanding you. I don't think I fully understand what you are asking.
If you force on the output, and forces are enabled, the voltage will be whatever the supplied voltage is. If you are getting varied readings, you could have a bad module or IFM.
Sorry to confuse you guys,
I have 1756 with a DO connect to 1492-IFM40F-F120-2. first 6 pins on F120 have 120Volt relay, the pins #7,8,9 don't have any 120V relay yet. When I force bit 7,8,9 (pin 7,8,9 on F120) I expect to see 0 to 120V, but I don't, I only see 116V to 120V. While other pin 1 to 6 work fine which I measure 0 to 120V. So my question is what wrong with pin 7,8,9 or I am missing something here ?
If your DO is triac (as I suspect it is) AND you are saying that forced ON = 120 VAC and forced OFF = 116 VAC then you are seeing the leakage current present a voltage to your hi impedance meter and is normal.
You would need to put a load on the output for the leakage current to be sucked down by the load - then you would see ~0 VAC when forced OFF.
Thanks for your answer, it help me to understand more about Panel & Controllogix hardware, I have no formal training in Control Panel, my background is Mechanical. Appriciate. I'll put a load on Monday to see because I cannot get online to force on until Monday.
If there is any explain about why/where leakage current present a voltage, please educate me !?
yes, DO are triac 120VAC
We have a project where we have the 1756-L82Es in redundancy with Remote IO Backplant via EN2TRs. Everything works and is redundant but we can...
368
Hi there! I posted few days ago about a fault i had with my motion. I did some cable check and replacement and it didnt solve my problem yet but...
370
Hello, We have a customer with a 1756-L72 ControlLogix PLC. They have recently got a T01:C62 Fault Code. I am trying to figure out how to...
1,047
PN1651 - ControlLogix 1756-OF8/B modules may exhibit spurious channel 4 through 7 faults. Rockwell just released this and we have an upcoming...
1,066
I was wondering if anyone else has had issues with the PA75 bricking on power ups. We had 2 that were a year old brick on us. 1 bricked when the...
859
