Question about using 2 Barcode Scanners with Micrologix
vha23
Feb 2003
27
Hi. As the title says, i'm tryint to connect 2 barcode scanners to a micrologix 1500 LSP (no additional serial port, just the programming port). Is this possible, or do I need a 1500 LRP. I did a search on this site, and came across this:
http://www.tomantron.com/index.html
Has anyone used this, or does anyone have any other ideas on what I could use? Basically, I'm looking to see if I get a good read or not on a scanner. I'm not looking to do anything with the ASCII string except to see if it is a NO Read or a good read. Thanks for any help.
Many scanners have digital outputs which can be configured to indicate read status. You may look into that if all you are looking for is is binary status.
thanks, i didn't even think about trying that. I'm so used to actually using the scanned data, I made this a lot harder then I needed to.
Hi all, I'm working on a safety circuit and had some question about fusing. Incoming supply - 120V/15A Power supply - PSL-24-060...
586
I know this can be done, but I can't get the router config right. My goal is to physically connect(using an ethernet cable) a device(PLC, RTU...
1,020
I'm a novice with Rockwell s/w and a rookie working with virtual machines. I needed a way to support multiple FTView ME versions. so I set up a...
2,966
I am looking to fuse only the commons of my IO cards to protect the plc. Each input point is rated at 6.5 mA with a total of four points, in...
2,756
I operate a distillation column for Argon gas. It has a pressure controlling valve that cools a condenser at the top of the column with nitrogen...
2,272
