Looking for S120 double motor module
samvivi7
Apr 2016
NJ
50
Hey All,
I am looking for help with configuring s120 double motor modules for the following motors.
SEW motors (X2)
K37DRE80M4/FC/TH/ES7S
1HP GEARMOTOR, 3.98, 1HP, 1" OUTPUT SHAFT SIDE B, M4, CONDUIT BOX 90, CABLE ENTRY 1
Name Plate to read: Voltage 220-242D/380-420Y 50Hz
Also, I am using Sinamics control unit CU320-2 DP if this helps.
Thanks.
How far have you gotten?
Automatic configuration yet?
i just realized that i wasn't very clear. what i am looking for is help with selecting a double motor module for that motor.
just need some to point me to a configurator or something.
Here you go
You didnt mention motor encoders but thats what the smc30's are for ( if TTL/HTL)
bold = quantity
6SL3040-1MA00-0AA0 1 Control Unit CU320-2 DP
6SL3054-0EJ00-1BA0 1 Basic
6SL3060-4AD00-0AA0 1 DRIVE-CLiQ cable; DRIVE-CLiQ cable IP20/IP20 (fixed mounting); 0.16 m
6EP1334-3BA10 1 SITOP modular 10.00 A
Drive system / Supply system
6SL3130-6AE15-0AB1 1 Smart Line Module; 5.00 kW
6SL3120-2TE13-0AD0 1 "Double Motor Module; 3.00 A
for the following axes:
Axis + Axis (1)"
6SL3000-0CE15-0AA0 1 Line choke
Axis / Drive system / Supply system
6SL3162-2MA00-0AC0 1 Connector for power cable
6SL3055-0AA00-5CA2 1 SMC 30
6FX2002-1DC00-1AB0 1 DRIVE-CLiQ cable; DRIVE-CLiQ cable (by the meter) IP20/IP20 (fixed mounting); 1.00 m
Axis (1) / Drive system / Supply system
Here you go
bold = quantity
Axis + Axis (1)"
Hey JRW,
Thank you so much for the help (y)
if it's not too much of trouble can you show me how you configured the module? for the future.
Thanks again
Sam
Hello All, Please direct me to post to the right page. I am really new to PLC, and want to find a tutor who is familiar with Automation Direct's...
479
187
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
261
can anyone has a good program to learn plc programming online. i have the basic looking into improve my skills thanks
196
I want to monitor a couple signals in a place where there is no PLC but there is ethernet. I know I can use an AENTR or Flex I/O and a module but...
21
899
