Largest industrial touchscreen HMI
phuz
Jun 2008
Mohnton, PA
1,045
I'm working with a customer who wants to upgrade their existing control room which consists of a lot of pushbutton control and numerous standalone loop controllers. They want a large touchscreen to replace the controllers on the main panel. Red Lion and C-More only go up to 15" and the new AB 5500 only go to 19". I am personally in favor of using Wonderware and looked into using it on a 24" touchscreen from Superlogics. This is a control room and does not need to be NEMA 4/4X. Are there any terminals that I am missing that should maybe be considered for this size?
Before you order, make sure it'll fit in a panel :).
24" will be a huge cut-out :)
Biggest I'd seen before that was a 22" panel (multitouch) from Siemens.
Hello friends. There is an int type, number that I got from the DataBlock. For example, the DataBlock address is Db1.dbw0. Here's what I want to...
32
10,554
Hi, I have a Redlion g series HMI connected to a fanuc lrmate 200id using the HMI software option on the robot (emulates a series 90 GE PLC) Now...
2,340
As I am a Jr automation guy I usually make lots of small changes or add on. but I had the opportunity to do a complete lamp board to HMI project...
3,028
Hi there I was just trying to find of 4 DINT values using below code On paper its appears to work fine but in PLC not !! Cant see what i am doing...
22
8,018
Is it still the australian mining company with 40.000(?) I/O or have the chinese gigantic powerplant even bigger?
20
5,423
