Allen bradley 1769 High Speed Counter configuration issue
Baila_Shah
Dec 2015
Perth
Hello all,
In my current project I am using Allen Bradley 1769 High Speed Counter with Compactlogix PLC and IO modules. The High Speed Counter is used to calculate the flow rate by counting the quadrature pulse input from the Flowmec flow transmitters.
My issue at the moment is the configuration of the High Speed Counter. The module creates Input,output and configuration tags but they are so many that I confuse which ones to use.
If anyone of you had a similar situation, can you please give me some advice? Also I would greatly appreciate any information information/study material regarding High Speed Counters. High Speed Counters are my weakest points and really want to get good grasp of them.
Many many thanks in advance šŸ˜Š
Cheers,
I have a 1769-L24ER-BB1B and I am trying to flash it to 34xx, its flashing red and faulted, when I try to flash it I get a popup stating it needs...
283
Hi, i want the above to control a 4-20mA valve using the 20mA signal to open the valve fully and a lower signal to partially open the valve how do...
2,574
Hi Guys, Question - does the subject title AB processor act as a processor AND comms module? It does have communications ports available on the...
988
Hello everyone, I am in the beta phase of building a SCADA system. Currently planning to use Inductive Automation as our SCADA platform, but...
2,168
hi, this is my first post in this forum, i have two allen bradley 1769-L30ER and unfortunately I want to make it redundancy. but I heard that...
3,064
