we already have a bunch of 377 panels and they are just pieces of ****
Funny that, we have MP277 touch panels and these are not a piece of ****, there again we use it to display machine status and an operator interface. It has basic data logging which we have not used yet and use Foxit to display PDF's, a limitation of Windows CE. We are not trying to use it as a large scale data logging device with active x control.
Oh hang on, we're using it as the tool it is mean't to be used.
I've often complained that my Mini was not a Rolls Royce, mind you if I stuck a Rolls Royce engine in it would probably look stupid.
Instead of critising a Mini because it is not a Rolls Royce how about buying a Rolls Royce instead of replacing the engine.
Siemens do Industrial PC Panels that run proper Windows, in case you were not aware, Siemens make PC's as well and a fairly big brand in Europe, the industrial stuff is below:
http://www.automation.siemens.com/salesmaterial-as/brochure/en/brochure_simatic_industrial_pc_en.pdf
Then again as you re based in the US you will probably have a hatred against all things Siemens, so there are plenty of alternatives around.
I would go nuts if someone in my division *******ised equipment that could leave us in the **** if something happened to him or the equipment.
