Studio 5000 Tag Descriptions
mjp123gp
Mar 2012
Savannah, GA
94
We have a new machine with L81e v30 that was programed with tags and descriptions in another language. After commissioning, the descriptions were converted to English for us. When I try to get online now, Studio says there's a difference and forces an upload which causes all my English descriptions to get overwritten with the original language descriptions. I've done the program compare and it doesn't show any task differences, only controller language.
I wasn't able to find any tech note from Rockwell. Has anyone else ran into similar issues?
I have not run into this issue.
I would recommend (as a work around) that you export the tags from the program that was translated, then upload from the controller (save it locally). Then import the tags from the translated program. This is not ideal for a variety for reasons and it requires you to take the machine down for a minute or 20. (Also, you will want to overwrite existing tags -- its an option in the import window.)
My current situation is a follows: I have two similar 1769 controllers with similar programs. Both have a UDT array that is being used to store...
269
Hey all, I'm doing a more standardize version of one of my programs and organizing things into UDTs and whatever else I can do to shrink the...
438
Basically I have created a bunch of local tags, is it possible to convert all of these to a global tag? Or would I need to re-add everything all...
1,255
I just had to move my Rockwell VM over to windows 10, so I have a new setup with versions 32-34. I'm having a weird issue where the columns in the...
631
Does anyone know if you can access the newish Tag Based Alarms in Studio 5000 in Crimson 3.1? There are some benefits to this if it's possible as...
1,695
