FactoryTalk View server location?
Bodo
Nov 2014
FL
Howdy Gang
I had a windows machine crash. I was able to reinstall and get FT installed. My issue is that now FT doesn't 'see' the server.
"FactoryTalk Directory Information" pops up and informs me that it's running local and not the server. Where can I change this setting?
Running FT SE 9.00
Sorry if this is fairly basic or vague....
Thanks for the reply.
Your reply rung a bell. I did what you suggested. Then I had to go into Admin Console and add the server.
Thanks! It's up and running now.
I am upgrading an old RSView32 v7.60 HMI to FactoryTalk View SE version 12.0 and I have an issue. There are some excel reports generated daily...
1,004
Hi, I'm trying to connect with an HMI on one of our machines at work. I have applied the correct pathway to the plc, via the FT Linx communication...
3,127
Hi, Can someone guide me through how to use FactoryTalk SE VB script to open communication with SQL Server? which command I can use? Are there...
2,295
I have nuisance alarm that comes and goes. Doesn't seem to stay longer for a few seconds, is there any way I can somehow add a time delay or...
1,503
I've found snippets on Rockwell's site about FTV 12.0 offering a redundant server license at a reduced cost, but my local AB rep knew nothing...
3,075
