FactoryTalk View SE DDE Server
RobKno
Apr 2015
Edmonton
I am upgrading an old RSView32 v7.60 HMI to FactoryTalk View SE version 12.0 and I have an issue. There are some excel reports generated daily that pull data from RSView32 via DDE. I see that FactoryTalk View SE supports legacy DDE communications, but only as a client. Is there a simple solution to allow FTView to serve up the data as before? If not, do you have any suggestions on how best to facilitate the excel reports?
Many thanks!
Update:
I was able to push data out from FTViewSE to Excel using a script. This works, but isn't the most elegant solution. Now that I've proven it can be done I need to get all the tag data sent to the correct cells in the excel spreadsheet.
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
115
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
130
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
177
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
121
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
200
