Able to ping to ENBT , but unable to connect on RSLinx
pssriram16
May 2006
San Francisco Bay Area
39
RSLinx version 2.57
Trying to connect to ENBT/A via Wi-fi. This ENBT card is on the back plane of Compact Logix 5345 CPU.
I am able to ping to the ENBT card, but when I try to connect thru RSLinx, then it times out (yellow question mark with red cross mark).
Any ideas why? Which port number does RSLinx use to talk to ENBT cards?
Sriram
The important one for connecting to a 1768-ENBT is TCP Port 44818.
I start with ordinary ICMP PING, then perform an ARP -A to be sure the MACID I expect is in the ARP table.
Next I try HTTP, because most A-B devices have an embedded web page.
If I don't get HTTP (some devices can have it turned off) I try TCPing to Port 44818.
If those methods all work, then you have verified basic TCP connectivity and you can start troubleshooting RSLinx.
If you're using WiFi, make sure you're not also simultaneously connected to a hardwired Ethernet network.
The EtherNet/IP driver uses a broadcast packet that can be blocked by some firewalls and VPN networks; try using the Ethernet Devices driver.
Hi everyone, I have a Siemens PLC and a CP. I have several devices connected via profinet on the CP PN/IO port. I also connected the G-BIT...
1,268
I'm facing a strange problem. I was asked to enable a printer on a PLC network, this printer needs to print from a chart recorder attached to some...
1,278
I am working on a well production control panel with a GE VersaMax (IC200CPUE05). There is a power issue on the platform with the solar chargers...
1,812
Dear Members: I have connected CX9020 with a high voltage power supply via canopen. I have loaded the PDO's from the eds file. I want to read and...
2,134
Hello all, I need to store the pointer-address of a database in an “ANY” variable. How can I do this? Example: When a variable is equal to 11...
2,676
