GE VersaMax Dropping Variable Values
Jan 2017
Gulf Of Mex
36
I am working on a well production control panel with a GE VersaMax (IC200CPUE05). There is a power issue on the platform with the solar chargers that is causing the system to loose power every night.
Each day when the system powers back on, the PLC resets all of the operator entered safety setpoints back to 0's. Or for some the setpoints will be set to -50 for the low and 1000 for the high, but they are all reset to some default value.
I fully understand that the power issue needs to be addressed, and I have 2 new solar panels and new batteries on order.
What I dont get is why these variables are reset to default values each time it powers off? shouldnt these be held up in memory by the CPU battery?
What software are you using to program the CPU? Machine Edition is the preferred package, as long as your hardware is supported. You should be able to set the Initial Value for each of the setpoints, so that it will be retained on power cycle.
I have the Proficy ME version 8.0. I was considering setting the initial values but these setpoints change from time to time after the operators run a range chart. so usually quarterly.
Is the way GE handles its data storage different from AB? I know with AB the data table values are stored on a power cycle, so they come back online with setpoints and analog reads already populated
It may be that there is a program and RAM info that is saved in Flash and auto relaoded on power up. Check this in the hardware config of the CPU change as needed the download the new config, saving to Flash as needed.
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
225
Hi, The VersaMax PLC suddenly stop running (no LED on run function) so I'm trying to upload the program. The HMI connected to it says "Host...
139
I do have a problem with a GE Versamax micro PLC. By going online (on Port 1) the "OK led" goes down. Power led stays On Port 2 no reaction at...
398
Hi, I am trying to set the IP address on the IC200UEM001 Ethernet Option Module. I am following the procedure in the manual for setting a...
437
I have a new computer and it doesn't have an ethernet port. I am trying to connect to the Versamax Micro Plus with a type c to ethernet adapter...
1,262
