How to be able to ping devices on profinet via PLC connection?
plcnoob69
Jun 2023
Nigeria
30
Hi everyone,
I have a Siemens PLC and a CP. I have several devices connected via profinet on the CP PN/IO port.
I also connected the G-BIT port of the CP wit my PLC.
I think there should be a way for me to ping the G-BIT and consequently all the devices that are connected to the CP via profinet.
Currently I am able to ping my PLC, but not the G-BIT nor the devices.
Could someone explain what am I supposed to do? How should I route these things?
If it matters, the PLC, G-BIT and profinet devices are all on different networks.
If your PLC was on the same network as the devices, it would not be a problem.
Even though it is separate networks are the connected together somewhere by an Ethernet switch?
A program like Profinet Commander might help.
I'm facing a strange problem. I was asked to enable a printer on a PLC network, this printer needs to print from a chart recorder attached to some...
1,280
I am working on a well production control panel with a GE VersaMax (IC200CPUE05). There is a power issue on the platform with the solar chargers...
1,813
Dear Members: I have connected CX9020 with a high voltage power supply via canopen. I have loaded the PDO's from the eds file. I want to read and...
2,139
Hello all, I need to store the pointer-address of a database in an “ANY” variable. How can I do this? Example: When a variable is equal to 11...
2,680
RSLinx version 2.57 Trying to connect to ENBT/A via Wi-fi. This ENBT card is on the back plane of Compact Logix 5345 CPU. I am able to ping to the...
6,339
