ASC800 "comm module" fault
Apr 2017
iran
hi every body
i have a problem in acs800 and i have 3 questions if anyone can help :)
the problem is: the "comm module" fault (FW 02.12) occurs usually and it has not been reset by the reset button on the panel.(but the drive is working and it is not tripped). it can only be reset by turning the DC voltage on and off or REFRESH (2.27)!! what's the problem?
now i want to write an additional block in DriveAP and use
BSET block to make it reset by reset button on the panel.
1- do you think it will help or not?
2-the reset button on the panel is included in which parameter? i mean when i push the reset button on the panel, which parameter and which bit is changed?
3-how can i have a complete list of ACS800 parameters? for example: parameter 2.26 is defined as "main ctrl word" but it is not included in ACS800 manual!!! and also it is different from parameter 7.01 (main ctrl word)!!
Hey guys. As the title suggests, I need to configure a Danfoss Aquadrive FC202 inverter, so that its logic inhibits the local command when the...
76
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
16
566
After updating a panel, I inherited another PLC for my "learning lab". It's a Modicon TSX Micro. I've not worked with a Modicon PLC yet, so I...
172
Guys need a bit of help getting the instance correct for a 22comme with a PF40P. Trying to get 2 things first is the drive current amp draw...
101
I have 3 new PowerFlex 7000 VFD's. Rockwell was out to do some checking before startup. These are part of a larger electrical project. I gave the...
360
