Omron Screen - Micrologix 1200 PLC connection problems
Worsley
Sep 2007
London
25
Hello all;
I'm having trouble connecting an Omron NT2ST display to an AB Micrologix 1200 PLC. I am using a 1747-DPS1 Port Splitter to allow connection of both the HMI and Prog terminal to the PLC at the same time. The message I get continuously on the Screen is PLC communication error, check PLC Power. Whoactive shows no sign of the screen. I can communicate directly to the PLC through the port splitter with my PC , but that's about it. Can anyone lend any insights into this problem?
Thanks.
Welcome to the Forum!
Check the baud rate setting on the NT2S.
Fairly sure the default is 9600.
Looks like the DSP1 expects 19.2 or 38.4.
I have used NT2S units connected directly to the 8 pin mini Din on the controller in the past.
Hope this helps.
Unfortunately, everything in the setup checks out. It just doesn't work. but thanks for the suggestion though.
Hey, gtsuport - do you recall what cable you have used in the past to directly connect the NT2s to the Micrologix 1200? I can't get the damn thing to work directly either.
Thanks!
See the attached image.
This is the cable connections I have used in the past.
Hope this will help.
Do you know of a way to reset the Micrologix 1200 to factory defaults without going online? I no longer have the ability to get online with this PLC. Things go from bad to worse.
Not much of an AB guy anymore, but from the manual,
there is a small button under the pots on the processor.
Hold down the button for 1 second or more and Channel 0
will be reset to default.
I am working on a project using a NB screen and NX1P2 PLC. I am having a really hard time getting a real number to properly translate through to...
144
Hello, I have an Omron NT31C that I am trying to upload a screen to from my laptop. The software on my laptop is NT-series Support Tool ver...
1,893
Hello all, I'm new to the Sysmac Studio software and I'm having an issue with the HMI screens crashing. I have a screen that shows the active...
1,995
Hi. For a project I’m programming a 10 inch Omron NB hmi. Now, creating an event or alarm screen is no problem, however all event related screens...
1,467
hi i have used the data history screen for data log purpose in Omron's NB Designer for HMI-NB7W-TW01B. i want to know if i will be able to clear...
2,236
