A to Q series Mitsubishi PLC upgrade & Touch screen
sttchui
Mar 2008
kl
81
I going to upgrade the A Series PLC to Q series PLC but the touch screen will remain the same
Can anyone help me to convert the A series to Q series PLC?
A series Q Series
Q3ACPU Q02HCpu(OR I NEED TO UPGRADE THIS Q12HCPU)
A61P Q61P
A38B Q38B
A68B Q68B
AX41 QX41
AY41 QY41
AX81 QX81
AY81P Q81P
AY23 QY22(2 PIECE FOR EACH AY23)
AC06B QC06B
AJ71QBR11 QJ71BR11
AJ72QBR15 QJ72BR15
(IF IS POSSIBLE TO CONNECT Q SERIES PLC AS REMOTE MASTER TO REMOTE SLAVE OF A-SERIES???)
TOUCH SCREEN
A970GOT-TBA-B
CABLE
A9GT-BUSS
A8GT-EXCNB
A7GT-CNB
AC06B
REPLACEMENT CONVERT TO Q SERIES
(ARE THIS DIRECT CONNECTION FROM THE BASE TO PLC? DO I NEED TO CHANGE ANYCONFIGURATION IN SOFTWARE OR HARDWARE??)
A9GT-QCNB
A9GT-QBUSS
CAN I CONNECT KEYENCE TOUCH SCREEN VT-7SB TO Q02HCPU PORT? ANYONE HAVE THE WIRING CONECTION TO THE COM. PORT?
THANK YOU!
Hi One of the PLC's that I maintain/update is a Mitsubishi Q-Series, probably installed about 10 years ago. At the moment, ALL the wires from...
1,171
Hello everybody! I found option for creating communication with Q series via python. But can't find any tips for connecting with PLC FX series...
5,407
using Q03UDV plc &QY42P for outputs.....working ok i want to use new output ..download the programm but output does not show 24 v in...
3,240
Hi, I need to send a digital output to turn a water pump Inverter driver ON/OFF. To this end, I'm planning to use a Digital Output Module, i.e. it...
3,530
