Mas01
Hi, I need to send a digital output to turn a water pump Inverter driver ON/OFF. To this end, I'm planning to use a Digital Output Module, i.e. it outputs a Y-value. It has 8 channels, but unlike the analogue modules, there doesn't seem to be any place in the code to configure/set-up the channels. I mean, if you look down the LHS of GX developer, you can see various things like ANALOGUE, DEFAULTS, MAIN but nothing for 'digital'. When I was configuring analogues, I had to change buffer UnGn values to get the PLC to recognise the channel, but there's nothing similar for digitals. Thanks
