small and very low cost device with ethernet
If you have access to a supplier with good OEM pricing, try the Turck FEN20-4DIP-4DXP.
I see them retail around $300, but I believe I had pricing from someone at one point around $100.
They do Ethernet IP and profinet and have a pass through switch which is great, all in a small footprint.
+1
..and it clips onto a standard 35mm DIN rail(!)
+2.
We've been using these recently and they are fantastic value.
It is a breeze to set these up as an IO device in a Compact or ControlLogix processor.
cheap solution is to use arduino leonardo runs on language C and costs 10 $
I'm pretty sure that would be more expensive than an off the shelf component if we account OP's hour rate. Not to comment on his technical ability, but only on the additional stuff he would need to build around it and the lack of certification of these components for use in anything.
Dear Friends, Facing problems with Wonderware view, My tags are very small and not readable, like machines RPM, pressure and temperatures like...
1,991
I need to detect the motion of a netting material as it moves by a small window. The material is a monofilament netting with 3/4" squares. I can...
19
5,915
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
712
Hi all, I’m new to programming and want to write a simple routine. Push start button, turns on sensor. 2 second delay before anymore logic read...
330
Hi! I'm wondering if PLCs are used for small-scale production. I've got four machines doing different things with textiles, and I'm exploring the...
1,339
