Unusual Switch / sensor needed Very Small.
If you have money to throw at it, you could use a machine vision camera.
You could detect for any missing parts, defects, misalignments...
Cognex makes a powerful one, it can detect missing pins in a connector.
This is a classical problem with a simple solution. Make a lever-arm arrangement that is moved by the material, and sense on the arm rather than on the material itself.
For example if the web moves vertically downwards, then the lever-arm can be like a small pivoted see-saw with a bit of weight on one side, so that it will naturally rest in a horisontal position. When the web passes by it forces the see-saw to pivot down on the other side. When the web disappears, the see-saw falls back to its original position.
Then use a regular prox to sense on the see-saw.
If the web moves upwards, or horisontally, you have to change the position of the weight and maybe add an angle to the see-saw. But the principle is the same. You get the idea.
In this way you can create a lever-arm that is designed to activate on the particular kind of material, wether it be super-heavy bulk, or like in your case very light and flimsy.
Is the material of the netting conductive? If so ground out the netting and have a probe hanging down wired to the 0V of a ice cube relay, wire the other side to your MCR +24V power. When the probe grounds out the relay will trip and give you a dry contact to the PLC to know netting is there.
I installed some Rockwell Autom. apps using the files with the MD5 checksums below. Can anyone please confirm that these are the correct files...
2,533
Good Morning , We have a IMI Buschjost 24 vdc solenoid valve coil that is very hot . About 192 degrees . It stays energized for very long...
2,376
I think this may be a bit unusual, and I'm not even sure this is realistic or if this is the correct place to ask this question. Please bear with...
2,360
Hello, PLCTalk Community, I hope you can help give me a little perspective. I'm doing an in-depth failure mode analysis on a system that uses a...
8,122
Today, Orbital ATK fired the latest of their five-segment solid rocket boosters (SRB's), at the test facility in Promontory, UTAH. The center of...
1,686
