Unusual (a little) use for a PLC
jdbrandt
Oct 2002
Pennsylvania
1,203
Today, Orbital ATK fired the latest of their five-segment solid rocket boosters (SRB's), at the test facility in Promontory, UTAH.
The center of the booster is supported by a large frame, and that frame is hydraulically controlled by a PLC, with a touchscreen interface.
It was built by a UTAH integrator, and shows up in the photos of the SRB.
This is the only known PLC in use on that test stand.
I can tell you we're using ControlLogix upstream of that engine, in the nitrators that supply the solid fuel plant. And we're very, very, very careful.
They test some hugely energetic stuff out there at Promontory. I always wanted to see one of their nighttime D5 rocket (from Trident II missiles) tests when they decommission the solid fuel motors.
I installed some Rockwell Autom. apps using the files with the MD5 checksums below. Can anyone please confirm that these are the correct files...
2,533
Good Morning , We have a IMI Buschjost 24 vdc solenoid valve coil that is very hot . About 192 degrees . It stays energized for very long...
2,374
I think this may be a bit unusual, and I'm not even sure this is realistic or if this is the correct place to ask this question. Please bear with...
2,360
I need to detect the motion of a netting material as it moves by a small window. The material is a monofilament netting with 3/4" squares. I can...
19
5,917
Hello, PLCTalk Community, I hope you can help give me a little perspective. I'm doing an in-depth failure mode analysis on a system that uses a...
8,122
