Panel View 300 question
boyd_man
Oct 2002
South Carolina
39
I have a Micrologix 1500 controller (1764LRP) and I have a Panel View 300 (2711-K3A17L1). I will be communicating to the Panel View from the PLC with cable (2711-CBL-PM05). I’m hoping I can use cable (1747-CP3 SER A) to communicate to my PLC from my PC to program the PLC and the Panel View. The Panel View will be connected to my PLC all the time with cable (2711-CBL-PM05). My question is first I’m sure I can use cable (1747-CP3 SER A) to communicate from PC to PLC but when I’m connected this way will I be able to communicate with my Panel View through the same cable while it is connected to the PLC.
No, the ML1500 does not support passthru comms. If you changed your PV to one that has DH485 comms and network PV-ML1500-PC together you could do
what you want.
Can I use cable (1747-CP3 SER A) to communicate to the Panel View from the PC to program it? If so how do I set it up, I can not get my PC to recognize the Panel View with this cable
No, the 1747-CP3 is a null modem cable. You need a straight thru cable for your PV300 ( see PDF)
Good morning, I would have a question to ask you. I have a Micrologix 1100 to which I have to connect a PanelView C300 in ethernet. I have...
2,080
Hi, we are using PV300 and using Panel Builder 32 as software. We are receiving the error code as 31. Please let us know how to clear this error.
7,936
i have a panel view 300 whos cat no. is 2711-k3a5l1 i am using comm'' cable 2711-nc13(rs232)cable when i connect it to pc and pv 300 after that i...
7,836
Hello all, I have a panel View300 - Model: 2711-K3A17L1 B A 4.41 (AB) By connecting it shows me 'ERROR 40' - Manual Error 40: Error firmware (...
5,262
Hello everyone! I'm trying to hook up two HMI(panel view 300) to the same PLC (micro logix 1500) using the same port as the other port is connect...
3,488
